Originally Posted By: SumpChump
Originally Posted By: car51
Hello again and I'm pondering this Mighty vac fluid extractor. If anyone has one, let me know how you like yours and what you use it for and any pros or cons. I'm planning on using it for changing ATF, fear oil and other things a shame I read a lot of good about them
Thank you in advance and what do you guys think of this one?
https://www.walmart.com/ip/27328256?wmls...13=&veh=sem
This is worth its weight in gold....
Mityvac 7201 Fluid Evacuator Plus https://www.amazon.com/dp/B0002SR7TC/ref=cm_sw_r_cp_api_VVtdybJJEX5TJ
That about sums it up.
I've used it to service a few transmissions, to drain the pan prior to dropping it, or to exchange or refresh ATF between pan drops when I'd rather not pop a transmission line. I've used it to drain radiators to get the level below the upper radiator hose to swap out thermostats, and a few other tasks. It works well for filling the transmission in my van with the M5OD transmission. I can put the ATF in the Miti Vac, put the tube in the transmission and fill it with ease. It beats pumping it in from quart bottles. Bottom line it was well worth the money.
