This is my tentative plan of action for the 2006 Honda Pilot.
Vehicle will be used sparingly, 4/5 weeks of the year and be stored unused during rest of the year, won't be started and warmed, butvrather parked up with the battery removed with a cover.
Usage will be varied, traffic density is quite high, fuel quality is decent as there is a good number of Shell Stations in the locality, will likely get the best quality petrol available.
All usage in Ghana. Mostly around Accra but also some longer trips.
As mentioned in my other thread I will be researching the parts to have the cambelt sorted out, unless I can find documented proof that it has been recently done.
Oil filter availability is not great but the Honda Legend made it to the UK with the 3.5V6 engine.
I have research the recommendations for the 3.5v6 engine using Manufacturers websites.
Oil.
1st Choice Mobil 1 New Life 0w40 £30 in Costco
2nd Choice Mobil 1 Super 3000 X1 FE 5w30 £
3rd Choice Amsoil or Red Line 5w20
Oil Filters.
1st Choice K&N HT 1010 £15 (ish) online from K&N
2nd Choice Bosch Filter £9 (ish) locally at EuroCarParts.
Air Filter ( I am limited in Choice, can only find a K&N so far!)
K&N Air filter. £53 (ish) Online from K&N
(Optional) K&N Cabin Filter. £64 (ish) Online from K&N.
That's the tentative plan of action anyway.
I was really interested in the reusable K&N oil filter but it's something like £240 and that makes no sense as even the most expensive K&N oil filter is under £15.
My reason for considering 0w40/5w30 instead of 5w20 is mainly due to the amount of idling the vehicle will endure in pretty hot temperatures due to congestion.
A few friends etc are in the Business of selling used engines. My concern is that the heat and idling time may be a factor. Though it could all be down to sporadic maintenance.
Oil.
Oil Filters.
