Originally Posted By: Kuato
Originally Posted By: 440Magnum
The data plate ON a pickup is FOR a pickup AT its maximum load (or else the door placard has multiple entries for different loadings). Put another way- if you have to inflate over the door placard in order to reduce observed pressure climb, then you have either overloaded the truck chassis OR you are using tires that aren't actually up to the job (wrong load range, or poor temperature class rating). Don't cheap out on truck tires.
Running tires grossly over-pressure (relative to the placard) is a good way to wind up with your own trailer stuffed in your radiator and the entire rig stuffed under a semi. The only exception would be if you change tire type (eg. put LT tires on a light-duty pickup where the door placard only covers P-metric tires).
Hmm interesting, because I thought my owner's manual indicated that higher pressures may be needed while towing or heavy loading.
But if your assertion is true:
Then please explain to me how several people were having sway problems with a light (4000lb) trailer, their max towing was 8000# or above, when tires were inflated to door plate numbers, but when they went to pressures closer to the tire's max, the sway problems went away. In some instances they went to HD tires, and increased inflation there.
Also, please explain to me how front tire wear on several vehicles I've owned was extreme on both edges and virtually nil in the center (classic presentation of underinflation) at the placarded pressure, which was then cured by inflating to maximum tire pressure? And by the way, this made handling much more secure in all conditions.
We may never agree on this point, just wanted to illustrate with things in my experience. IMO the placard maximizes the ride quality of the vehicle, NOT
necessarily performance or load carrying capability. In fact, a lower tire pressure results in a lower carrying capacity for the tire than a higher inflation pressure.
Please see:
http://www.tirerack.com/tires/tiretech/techpage.jsp?techid=195
http://www.fourwheeler.com/how-to/wheels-tires/1407-understanding-tire-load-ratings/
http://www.f150forum.com/f82/tire-pressures-weight-carrying-capacity-221869/
Exactly!
You will get "squirm" if you don't have enough pressure in your rear tires when towing. Especially with those tires that have soft sidewalls. This MAY NOT be the pressure indicated on the placard.
