So this is weird...
California
I worked on a friend's 1998 Chevy Tahoe - his dad took it into Midas and a hack job local shop for new cats and cylinder heads a while back - truck was losing coolant and I saw lots of Dex-Sludge form. The hack job shop replaced the heads but didn't use the newer Fel-Pro PermaDryPlus LIM gaskets. I replaced those and I got the truck to fire up on the first try. Of course DTC P1345 - cam/crank correlation was set and I did replace the knock sensor with an aftermarket one. Last week, he said the truck was feeling sluggish and he could smell gas - misfire. I pulled codes, and I saw a P0326 DTC show up along with the P1345. I finally figured out how to get TorquePro to show the GM CMPRET PID to get the engine "re-timed" and we retimed the motor at Costco's parking lot - we needed to get wiper blades, go figure. The truck was finally running smoother.
And then on the drive home, I saw the CEL turn on, then turn off. A mile later it flashed and I knew something was wrong, ECM logged P0302 and P0304 - but the knock sensor P0326 DTC was gone! Turned out whoever replaced the heads or the plugs and wires routed the #2 & 4 wires against the exhaust manifold. I replaced the passenger side bank of wires and the CEL was off after 2 miles of driving - I assume the misfire monitors didn't pick up anything. He ordered AC Delco's professional line, the wires I pulled were Prestolite, they looked the same.
My question is - could a shorted/burned plug wire send stray voltage through the engine block and cause the ECM to think the knock sensor is going bad?
Knock Sensors are notoriously unreliable. Think about it ... it's looking for an unusual vibration, possibly in a narrow audio frequency band, in a world of vibrations of a host of audio frequency bands. It's little wonder they are often fooled or simply don't work. With a KS fault, I would think almost anything is possible. I also would not worry about it or read too much into it. She works now ... problem solved, move on.
A damaged ig wire that's making sparks in the engine compartment can radiate EMI that can be picked up in other nearby wires.
The knock sensor generates a small electrical signal that could easily be interfered with.
