Originally Posted By: JTK
Originally Posted By: jonnied1
Looking at the Mobil 1 High Mileage synthetic oil. Which weight oil will provide the best protection in OPE under heavy loads in moderate temps (70 to 90 deg.). I've read that the 5W-30 will shear less than the 10W-30. Fact or not? Am I off my rocker on this?
Thanks.
Either would be a great oil. Like others have mentioned, theoretically, 10w30 would contain less viscosity improvers, etc, but any concerns caused by this would be tough to quantify.
I personally see no need or value in 10w30 with the 5w30s we have available today.
They make better long life oils, for example Liqui Moly Synthoil 10w30 is about as good as it gets if you need a 30 grade and want to do extended OCI's. I would not say the same about non German (Group 4) full synthetics, so you do need to compare like with like in base stock terms.
