First cut and post, and what a pain! I definitely need to invest in a filter cutter. I thought I could breeze through it with tin snips, but not the case! I really had to fight to get this thing open but got it done eventually. This filter is primarily used on a variety of GM cars. It had been dropped and dented on the corner and was destined for the trash can so I saved it and took it home from work to dissect it.
I completely spaced off taking a picture of the date code, but if you zoom in on the can, you might be able to read it and post it. I don't know how to decode them. Not going to dig through the trash to find it either! Haha
Looks like some leftover RTV residue here, nothing to be concerned about, RTV doesn't come off easy at all once dried. Although the QC is a bit sloppy IMHO.
Good, open louvers. Unlike most people here, I'm not afraid of louvers as long as they are open right and I can see the filter media. In all truth, the bearing clearances in an engine are much smaller than any louver we see on a filter and oil still manages to squeeze itself into those passages so people really shouldn't be losing sleep over this. A filter will not run in bypass mode because of louvers like this!
I did notice something peculiar about the ADBV, was these formed molds from the baseplate holes, they weren't cut or anything but molded into the nitrile itself. Haven't seen anything like this posted here before. I have one more new Performax filter, and when I get around to cutting it open, I'll be curious to see if the ADBV is like this.
I ran my fingers over the inner baseplate holes, and didn't find any sharp edges or burs that would cut into the ADBV during the OCI.
