So I looked on my shelf of lubricants and stuff this morning before heading off to work. I need to do some consolidating!
My 1998 Chevy Van calls for Dextron III in the 4L80e automatic transmission.
I found have a partial gallon of Coastal DEX/MERC, half a gallon of O'Reily's DEX/MERC (which I used the other day), a couple of quarts marked just "Dextron III" and a partial quart of Dextron IV.
I tried to research if any of these could be mixed or substituted for Dextron III and all I can find is for use in manual transmissions.
Plus Wikipedia say Dextron IV never existed, yet I have a quart of it!
https://en.wikipedia.org/wiki/DEXRON
The question is can I combine all of these together and use it in my van's automatic? This may sound like overkill but my plan is to put about 500 miles on it since I changed the filter, pull the drain plug out and dump it, refill it with fresh fluid, see if the fluid on the dipstick is red, flush once more next time I change the engine's oil.
