2004 Honda Accord, 5 speed - Replaced the valve cover gasket which was leaking a little bit. Took the opportunity to check the valves and most were perfect at 100k miles (I had adjusted them previously at about 50K). Pretty clean I think. I'm the original owner and have used a lot of different oils over the life of the car. Current fill is Castrol Edge 5w/20 synthetic.
