sprite1741
Thread starter
Originally Posted By: Trav
Again thanks for posting this great info. Not to hijack the thread but this is also a inexpensive part that can be installed when the pan is down for a filter change, I put it on every one.
http://www.sonnax.com/parts/2534-differential-lube-tube-retainer-kit
Thanks. I remembered seeing that a while back and checked those tubes when I changed fluid and filter the other day and mine were tight. I should order that and have on hand and install next filter change just to have one less worry.
