Been using this oil in my Yamaha XJR 1300 for the last few years with no problems. I change oil at 10k klms as recommended by Yamaha.
Changed the oil fews days ago with same oil out of a new container. Went for ride and noticed engine vibration which is very unusual for this aircooled 4 cyl engine.
Did the usual checks such as engine mount bolt tightness & chain slack & all other bolts i could find,none were loose.
So had a look at the new container of Motul & was shocked to see 'Product of Vietnam ' on the back in small print.
Did a little googling and sure enough Motul have a facility in Vietnam to service the Aisa/Pacific region.
Im from Australia so Vietnamese blended Motul oil for us now instead of the French blended oils.
The old containers all were 'Product or made in France '
All i did was to change the oil & now have this vibration,cant be 100% certain its the oil but seems odd suddenly have engine vibrations.
Maybe new oil is not same quality as french made...but certainly is no cheaper than before.
Cheers
Cheers
