Car was fine until I had to put a fuel filler neck in to pass state inspection. Not for OBD-II but for generally rustiness.
Used a new spectra neck from Rockauto. This POS is ill fitting-- sticks 1/2 inch out of the rear quarter panel. But it is/should be vapor and fuel tight on the hose nipples. I've run a couple tanks through with no problem.
Got a P0440 almost immediately. Takes two trips; first sets a pending code, 2nd locks it in.
The hoses and clamps are fine... the gas hose, a 5/16" hose, and a 3mm-ish super-tiny hose.
I got a screen grab from "Techstream" that seems to show it works fine when the built-in vacuum pump does its test but not without. So the tank will hold a vacuum and pass? I don't fully understand...
Finally, they made me do tank straps as well. I was ginger but might have smooshed something tender up top, rust-wise. I pulled the rear seat and checked through a plug in there that views the top of the tank... has surface rust but it doesn't leak fuel when filled.
Thoughts?
Thoughts?
