I bought a 2002 Suburban with a 5.3 knowing that it had knock sensor codes. Low voltage on both sensors according to my scanner. I replaced both sensors and wiring harnesses along with new felpro intake gaskets. Under 100 miles later codes came back. I have cleared the codes several times and keep getting the same ones back.. In my head i want to rule out that i got two bad sensors..and dont want to do the job again and get the same results..
I have done some reading and it may be possible that carbon on the piston crowns is causing this..but there is isnt a ton of info relating to this except for 'seafoam it'..the more techy forums recommend the GM upper
Truck runs great, not pinging on loads or hills. Gas mileage is good for what it is 14-16 mpg in mixed driving.
Ignore light? Redo with different sensors? Try a carbon cleanup?
