This is regarding my 2003 Ford Escape with the 3L Duratec, just under 110,000 miles now.
Occasionally the car is very hard to start. As in once every couple months, I have to engage the starter multiple times for a few seconds at a time for it to catch. It acts as if it isn't getting spark/fuel. But once it starts, it runs great. 99% of the time it will turn over maybe twice and fire right up. I have owned the vehicle for over 3 years and it has done this since I bought it. I figured the major tune up I did to it before last summer would take care of this issue, but it has done this a few times since. No check engine lights or stored codes.
Engine wise, the following has been done:
Spark plugs
All 6 ignition coils
IAC valve
PCV valve
Full Fel Pro gasket set - upper/lower intake gaskets and all gaskets above them
Cleaned throttle body
Cleaned MAF sensor
Cleaned EGR
And the regular maintenance like air filter, fuel filter, ran fuel system cleaners, etc
I am sure I am missing something
Does anyone have any suggestions? I am leaning towards an intermittent failing sensor of some sort. Maybe a coolant temp sensor or something? I do not want to wait until whatever the problem is to fail and leave me stranded this winter so any help is greatly appreciated!
Spark plugs
IAC valve
PCV valve
Cleaned MAF sensor
Cleaned EGR
