so i was putting a pigtail connection for my optimate3+ computerized charger on my bike last night, and after i had it all connected, i wanted to adjust the eye terminal on the positive side... while carefully doing so, or so i thought, for a split second the end of the wrench touched the exhaust heat shield and there was a single brief spark. anyone think the battery is damaged? the bike started fine, multi meter showed 13.25 v, and the optimate goes through its programs and shows the battery as testing good (i believe its a 30 min voltage retention test)...
i ask because i just wanted some opinions, i don't want to take a ride thinking everything is fine and have to push start a couple hours later!
