1979 300sd w116
Got around replacing the Front Brake Calipers (ATE) today.
LF brake caliper went on without a problem.
Right Front (RF) brake caliper does not fit.
The outside of the ATE box has the following information: 230042
24.9260.-8026.5.
I installed the upper caliper bolt first.
I then went to align the lower hole to the caliper hole and the holes would not align. Pushed in the caliper a little more and when the holes came close to aligning the caliper was observed making contact with the outer part of the rotor (the part where the lug bolts are installed).
I have a feeling that I got a caliper that is not for my car.
How can I reference the outer box number?
The part numbers below are from the auto parts website and belong to my car.
Again, I feel that the problem might be with the actual brake caliper but I could be wrong
I did read one review where a guy had a problem with the correct ATE brake caliper not fitting
1164200083 (0024211898, W0133-1599978, W0133-1612359) is for the LF caliper
1164200183 (0024211998, W0133-1600264, W0133-1615114) is for the RF caliper
Please advise
24.9260.-8026.5.
Please advise
