I don't have a dog in this arena. I do build BBC engines for hi-po applications. I do not build tight engines, but rather what I call droolers with extra oiling. Big ends are looser than OEM specs. And they are broken in on most often on VR-1. Once broken in, they are changed to Delo 400 15W-40.
Since VR-1 is no longer saleable in Kalif (
), I have now acquired a stash of Delo 15W-30 SD (severe duty) for new motor break-in and they will still be changed to XW-40 for street. Why, because the street around here can mean long periods of idling or low RPM while creeping through traffic and I trust a good 40 better in those situations. Coupled with a loose converter, it means lots of idle, blast, idle ... driving.
None of the current crop of mixed fleet HDEO's are bad. Some are better than others at some things. The OP does not have one of my engines. He can live on a 30 probably. But all the folks suggesting Rotella T6 are prolly the most right on. Why, because even though it's labeled a 40 (at op temp) it's on the light side for a true 40. I say it's really a 35 and that ought to be just what this 8.1wants when pulling hard.
In addition, even though it's it's a wide spread oil, it is a synthetic (USA style) and very robust oil without any chatter about ring sticking or any other faults. It gets used in all sorts of vehicles that it might not be thought applicable and it always comes back looking like a good choice. Ask the turbo Subie owners, or the Buick GN guys, or the Saab guys...
And I've seen my share of innards of BBC's, some run on Rotella and they look OK. Nothing out of the ordinary. No stuck rings, no abnormal wear patterns, nada ...
It's cheap enough and it's readily available. Run one cycle and do a UOA and see what you get. It's good for a one year change interval easily. Maybe two
