I have had to remove perfectly new filters with the below type of oil filter wrench because I can't find my simple cap wrench. For one reason or other, I had threaded the filter on after draining the oil and then decided to remove the filter...but the filter was actually unused.
https://www.zoro.com/westward-oil-filter...mp;gclsrc=aw.ds
I usually use that wrench when I don't care about my oil filter.
It dents the filter up upon removal. I was curious as to how bad a dent you can sustain and still have a good filter? I don't really understand what filters are like internally, but I'd assume that there are pleats sitting right underneath that casing.
I'd also guess that I'd be crazy to use a filter with any damage at all.
Thanks
Thanks
