Originally Posted By: Nick1994
My auto will get around 33-35 mpg if I drive about 65 mph.
Timing belt really isn't that hard to do, mine will need one soon. Was a $100 kit by Gates (or Dayco?). Alternator off, both serpentine belts off, timing belt plastic cover off, harmonic balancer off but crank to TDC, mark timing belt with white out so you can count the teeth, take off tensioner and pulley, bolt new pulley and tensioner on and slip on belt and reassemble.
Luckily you'd have your Tundra as a spare in the meantime if you got stuck with something.
Yeah, I recall you saying it wasn't that bad. Am guessing a 2 weekend job (maybe less--once home I could work into the evening, just checking in on the kids). Only issue being, it technically drives up the price on that 5MT one--I'm dithering on calling. I did wimp out and email on one of them--don't really want an auto, but they are reliable units, and that one would leave money in the repair fund.
Did you pull the oil pump and do the o-ring on that? I passed up on a $400 '99(?) Camry 5MT--once I saw the massive oil leak I walked. Guy said it needed an oil pan gasket, but it was way too much oil for that. Got home, looked it up, common failure mode. Oh well. It's of course buried in with the timing belt, so I'd probably R&R that at the same time as the belt.
