Most serpentine belts seem pretty good these days. Not a hard part to make correctly.
Goodyear Gatorbacks used to be the thing, at least on the Ranger forums. I just use whatever now. I put a lower grade Napa (Dayco?) belt on my '94 Ranger over a year ago and it is quiet and looks fine.
A Dayco Poly Rib on my '02 Ranger showed some white stitching across the belt after some miles, but didn't make any noise or anything. Dayco replaced it for free in exchange for the old belt. The new one has been fine.
Originally Posted By: JHZR2
I've heard Bando... Gates is good, but a lot are becoming Mexico Sourced. For this reason I used an AAP Dayco on my last job and have been happy.
Bando is the OE belt for many makes including Honda.
Only good aftermarket brand I know are the Goodyear Gatorback belts since they are the only ones using that rib design. Then you have Gates, Bando, Mitsuboshi, etc.
I vote the fleet runner by gates, it is green. I've used three of them and never had a problem. Also they visually pass the quality test with the rubber that's used being soft.
