Analyze these plugs from my 2005 Ford Focus. I had been alternating between NGK platinum and Autolite platinum while I was having drivability issues. The car ran a little better with the NGK's. The trouble turned oout to be a weak ignition coil that has been replaced. I think the NGK plug is a little hotter than the Autolite because 2 NGK heat ranges are spec'd for my application and this plug is the hotter one.
I see deposits on the center wire
Thanks for your expert analysis'!
