Trying to get my Buick's climate control working again. It's Limited trim with automatic temp. control. The fan works when hot-wired, but when hooked up through the harness none of the CC modes or fan speeds get the fan to come on. All the blend doors, etc., work correctly. The control panel (the part with the LCD and buttons) has been tested by an outfit that remans them and was good, so I'm down to the blower module and HVAC programmer. Going through testing procedures for the blower module, all voltage inputs to it test correct except that I have a constant 9V on the signal wire from the programmer, regardless of fan speed setting. What next?
Thanks!
Thanks!
