Originally Posted By: 02s4audi
Also we are in NY so our Temps right now are 40 over night. But this makes noise at all "cold" starts. I figured that it could be related to oil not getting to the valve train quick enough, hence why I was thinking 0w to get it there a little faster
Not at 40F. You could try the process of elimination. Try a different brand filter. If that doesn't work try moving up a grade to 5W30. I'm thinking 5W30 is going to help.
If that doesn't work and it is still bothering you then you'd have to consider a mechanical fix, as mentioned in this thread. I'd try the easy stuff first.
