Is a "gravity flush" an acceptable way to flush old fluid from the reservoir and clutch slave cylinder? As long as I don't allow the reservoir to run dry, I can't see a problem with it.
The service manual recommends the two person method, with one person under the car at the bleeder screw, and another person at the pedal, very similar to manual flushing/bleeding of brakes (i.e. push on pedal--open and close bleeder--release pedal)
