Originally Posted By: Ohle_Manezzini
Change the filter or clean the cam shaft passages and ir other passages. Maybe a flush?
Running a mild solvent flush on a 4 year old Korean car with a mild harmless noise? Why? Trying to fix a problem that isn't there.
Or he could just do, like you, and wait the problem to become catastrophic. Noise is problem. If not, why bother to open a thread if is harmless (now)?
What are you talking about? I've never had any catastrophic engine failure and I'm also not paranoid. You folks that hear ANYTHING slightly different in your car immediately blame the oil, flush it with kerosene, run 6 changes of Pennzoil Platinum for 300 mile intervals and expect something to be healed look ridiculous.
