For my older Toyota 4Runner, the original manual calls for the following greases on the driveshaft lube points:
Slip yoke: Molybdenum based NLGI grade 2
Double cardan joint: Molybdenum based NLGI grade 2
U-joints: Multipurpose lithium based NLGI grade 2
Then they issued a TSB stating the following:
Slip yoke: Multipurpose lithium based NLGI grade 2
Does anyone know why they might have changed the double cardan from a moly to MP grease? Is a double cardan joint not essentially just two U-joints? Why would they require different greases?
In general, what are your thoughts on what the proper grease is for the various driveshaft lube points? There still appears to be controversy on using moly based greases on bearing applications (like the U joint). I noticed older greases might only be rated GC or LB (chassis vs bearing), of which I am guessing that could be why Toyota specified a different grease on each point. However, almost all modern greases, moly or not, are dual rated GB-LB so is there any real reason to use a different grease on each lube point?
If a modern good quality grease such as the popular Mystik High Temp JT6 is dual rated GC-LB, is there any reason why this can't be used in place of a moly grease? Often times I see high quality MP greases having better Timken load, wear/weld numbers than some moly greases.
