Originally Posted By: CR94
Many of the particles appear to be sizes the filter should've captured. Therefore, either the filter failed, the filter was clogged and bypassing, or the junk came from outside the engine.
That's a duff deduction, in principle, and by experience.
If the particles are heavy enough, they may settle out in the sump, and not get to the filter.
If the particles are big enough, they may be stopped by the oil pickup strainer, and not get to the filter.
This of course does mean that the filter has not failed, the filter was not clogged and bypassing, or that the junk did not come from outside the engine, just that these are not the only possibilities.
