Originally Posted By: bioburner
Guess I should have posted this with the original post and picture. This is the same stuff electricians have to use when putting aluminum cable into lugs
That is basically called Penetrox. It is used when bonding disimiliar metals to prevent galvonic corrosion. Used in electrical panels where aluminum wiring is joined to another metal, copper etc.
