- Joined
- Nov 19, 2015
- Messages
- 1,462
Originally Posted By: yugrus
Here's what I managed to get out of my Maxidas scanner. Fully warmed-up engine at idle, in park.
Desired idle: 600 rpm
Engine speed: 593-616, varies fast, and that's the issue.
MAF: 5.27-5.33 g/s
Air flow calculated: 4.99-5.21 g/l
APP indicated angle: 0%
TP indicated angle: 3%
MAP: 32KPa
Intake manifold pressure: 69 KPa
Commanded A/F equivalence ratio: 1. This stumbled me. It was I red, and I don't think that this is right...
HO2S B1S1: between 70 and 800 mv, cycling nicely.
B2S2: 725 MV
B2S1: same as B10
B2S2: 700 mV
Fuel trim cell:6. Not sure what it is, but should be 0...30
Vehicle speed:0
TSC slip speed:between 5 and 15. Could be -200...4000
No EGR valve on that motor, as far as I know.
Will wait on what you guys think...
Your truck is fine.
That's NOT the issue. Literally every engine will fluctuate +/ 50rpm constantly.
MAF: 5.27-5.33 g/s
MAP: 32KPa
B2S2: 725 MV
B2S1: same as B10
B2S2: 700 mV
Vehicle speed:0
Your truck is fine.
