vettenuts
Thread starter
OK, just found this in my Workhorse manual (Workhorse is the chassis manufacturer, GM was the engine builder). Not sure Rotella is a good option now.
On page 18 of the Chassis Guide published there is a chart showing the recommended oil viscosity for their gasoline engines. In the bottom right corner of this chart it clearly states "DO NOT USE SAE 10W-40, 20W-50, or any other grade oil not recommended."
In addition, outside and just below the chart, there is a more definitive explanation paragraph that says "NOTE: 10W-40 has been removed from all Workhorse recommendations..........Testing showed 10W-40 oils tended to be more prone to ring sticking......Workhorse also does not recommend 20W-50 motor oils."
With the note on ring sticking, now am wondering if Penzoil Ultra Platinum or Penzoil Platinum might be a better choice even though the viscosity is near the bottom of the 30W range at 100 degrees.
