Guys,
I am attempting to measure consumption on my Subaru, but I need some help.
I used to be great at math, but not so much any more. I'd like to use my existing method to ensure consistency but I am having a little bit of trouble.
Below is what I did:
So I measured the distance from the top hole of the L on my Dipstick to the top hole of the F on the dipstick at 20mm with dial calipers.
I took a 431.6 mile trip and found that the oil level had gone down by 10.2 mm.
By my calculations, the engine consumed 51% of one quart and went 431.6 miles. I could rest here and say that I got about 850 miles to the quart, but I'd like to know how to reliably and quickly determine how much oil I burnt using this method if I check the dipstick after say 300 miles and the oil had gone down 35%....just a hypothetical.
I marked the exact location where I nest the vehicle and I wait a few hours before checking the dipstick.
My math tells me that the vehicle went 854.57 miles on a quart of oil, but I am not sure how I reached that conclusion or if it is even right. I always approached math differently than most and was never able to explain how I did it and in turn was really unable to understand how others did it.
I am sure that there are other methods, but I'd really like mathematical help with this one. The intent of this thread isn't to discuss the actual oil burning of the engine either. I have another thread for that.
Thanks for your help.
