Anyone here use this oil? Seems to be top notch from I can gather! The penzoil platinum in my truck is causing leaks from the oil pan and oil filter! Filter is tight..truck is a high mileage 5.3
I would check your oil filter adapter gasket if applicable and re gasket your pan.
Changing oil won't stop a leak that is major or increasing.
I know on my granddad's Chevrolet with the 4.8 the truck had never leaked a drop, put in Mobil 1 and truck started leaking. Swapped back to the QSGB he'd been using and the leak stopped. I know its not supposed to happen but it does sometimes.
Although some people on here think its ok to use a synthetic oil in a high mileage engine im not one of them i think your best bet is to go with a good high mileage engine oil... How many miles on that 5.3
I have used PHM for a long time and it worked well However i changed to Mobil super high mileage and that also is a good oil.
Originally Posted By: crazyoildude Although some people on here think its ok to use a synthetic oil in a high mileage engine im not one of them i think your best bet is to go with a good high mileage engine oil... How many miles on that 5.3
I don't think it can be beat cost/benefit wise. There are lesser oils selling for more, but you can't get a better oil for less (unless it is some semi-random $1/qt sale). UOA always seem to come back better than expected.
Can't go wrong with it. That's what I'm currently running and have another jug in my stash. Dare I say Chevron Supreme has a stronger add pack. Also, Chevron Supreme is running a $5 rebate through the end of October.
Havoline has always been a good oil but who has it at a great price..?
Search around. Amazon has it for $11.77 for 5 quarts. Sams Club often sells it for about $2-$3 quart for a 12 pack. It is often a Oreilly, AdvanceAuto sale oil. They also add on an additional $2-10 MIR as well.
No I'm not expecting it too...and changing the gaskets this weekend.....penzoil created the leaks!! I keep a close eye my truck
And caused lifter tap, all in the span of what - three weeks or less?
Yeah, okay.
Well then what else caused it? The only other thing is the oil
