JHZR2
Staff member
I'm looking to add some un-noticeable task lighting in an established space. Don't need a lot, and I want to use some of the cut-to-length LED strip lighting.
It comes with a 120v power supply, some wiring to the strip,and then the strip itself.
I'd like to drive a few sections of this strip off of the one power supply, via a terminal block. Each strip will be a different length and thus load.
Does anyone foresee an issue paralleling multiple short lengths of LED strip?
