My 2014 Tahoe (previous gen 5.3L) is silky smooth at idle. That is, when the car comes to the stop, and this lasts for about 5 seconds. Then the RPM begin to fluctuate quite a bit, between 490 and 530, and it is quite noticeable. It doesn't pass water bottle test at all, and the vibration could be felt through the body.
The MAF sensor and the throttle body are squeaky clean. LT fuel trims are the same and very close to zero under steady driving conditions, so I conclude the injectors are fine too. AFM is tuned out, and two-stage PCV catch can is used, no oil in the intake to report about. MMO in gas on regular basis.
I read the hint that ECU might lean out the idle to the edge of stability to save fuel. Very plausible, and if confirmed, would it help if I adjust injector's slope in the way that the computer would think that injectors are smaller then they are? So it would extend the injection cycle a bit, making the mixture less lean? I'm sure it is easy to do with the tuner, like Intune that I have.
Whold this work? Or the ECU would pull injection timing because of the O2 sensors?
What else could cause the rough(er) idle that you don't expect from a large engine?
Thank you everyone!
Thank you everyone!
