My mom has moved closer and I will be starting to take care of most of her maintanance.
She has a 2007 Saturn Vue with the 2.2 L (Ecotec?) motor with an automatic transmission. She has ~140,000 miles on it now. Most oil changes have been done at an oil change place by her house, not sure on what oil or filter. I have done a few for her over the years, usually with conventional 5w-30 oil and whatever filter (cartridge type Supertech, Fram etc).
Most of her driving is 50+ mph, maybe 8,000 miles a year. She is easy on the accelerator, summertime temps are 100°F+, wintertime may get to just below freezing a few days a year. Her car is parked outside. I think the 5w-30 recommended by GM will be fine for that. It does not burn oil, but has a small oil leak (more like seep) at the valve cover, but @ 3000 miles on the oil it is still almost full on the dipstick.
I was planning on using a Fram Ultra and some Pennzoil Platinum 5w-30 I have for her next change.
Her car does have an OLM, so I was thinking when the OLM says change, just do a drain and fill leaving the filter in for another interval.
No idea what the current OLM interval is for her (I found out she has been doing every 3000 miles like her oil change place suggests
) So it will be interesting to see what the OLM actually says. I guess if it is closer to 10,000 miles I will change the filter too; although I have read that most of these OLM tend to turn on around 5500 to 7000 miles, and if that is the case, I will do 2 oil changes on the one filter.
I am also hoping for another good Advance Auto or Auto Zone clearance this winter to add some more 5w-30 syn to my stash (I have a ton of xw-20, but only 5 qts of 5w-30).
