- Joined
- Apr 13, 2013
- Messages
- 3,220
Over the past year, I've had to do some repairs on my Accord that're more-or-less expected at 200K miles:
- Front O2 sensor
- Distributor cap, rotor, o-ring, spark plug wires
- Valve cover gasket
- Tranny drain & fill
- Rear brakes
- Rear hub bearing
- Timing belt, drive belts, water pump, tensioners, seals
- Tie rod ends, lower ball joints, CV axles, alignment
- PS pump
- New gas cap due to CEL
- New rad cap
I remember driving it off the dealer lot 15 yrs ago. Hope to take it to 300K+ *knock on wood.*
- Front O2 sensor
- Rear brakes
- Rear hub bearing
- PS pump
- New rad cap
