Everyones Favorite 5w30 Dino And Why?
Originally Posted By: Garak
Originally Posted By: zeng
Both the Chevron Supreme 5W20 and 5W30 are blends.
They aren't dino ...dude.
That may be true, but they're still marketed and priced as conventionals, not as blends.
+1
Originally Posted By: gallydif
^ Yes, OP's context is very clear. Question is why were you trying to steer it off course with technicalities by opening up pandoras box.
+1
Originally Posted By: Marco620
I'll go PYB 5w30 or QSGB 5w30. Least favourite...VWB/Napa Dino .
just curious, why dont you like vwb? or the other one?
years ago used Castrol GTX, Mobil super 5000, then switched to Motorcraft blend 5w30, then went to synths with Amsoil.
now I`m seeing the new Nissan Murano is using Dino, so back to the drawing board and some reading/catching up to do.
If I was using the amount of PCMO the OP refers to I would either use a bulk drum or a SOPUS Ecobox versus fiddling around with 5 qt jugs.
