Originally Posted By: artbuc
Originally Posted By: Ducked
Can't you clamp it on?
No way. Flex pipe is welded into a plenum. When you cut it out there is nothing to clamp on to.
Use an insert?
I've done that a few times to fix fractured exhausts on pre-cat cars, but those are of course different, and older, animals. Maybe there's nothing to locate an insert inside the plenum.
(I've even used stainless, but only because there was a slightly specialist scrapyard near where I lived. I suppose it reduced the cross-sectional area, but I managed not to worry about that.)
