Originally Posted By: Wolf359
Originally Posted By: chiefsfan1
I use 91 octane no moonshine added in my OPE. The beater Sable gets 87.
The Camry usually gets 87, although I do run 91 every once in a while.
The manual says 87 is the minimum. That leaves a huge door open on what octane to use.
Now it does have the VVT and a 10.4 compression ratio.
Butt dyno says it runs smoother on 91 octane.
Yeah, there's so many variables that the butt dyno is pretty inaccurate. People don't seem to understand what standard temperature and pressure is. You then adjust performance numbers based on what the current temperature and pressure is. It's worse when it's higher and better when it's lower. So depending on the temperature, humidity, altitude, driving speed, all those factors will affect fuel economy. And it's puzzling why people are doing their own experiments when the manufacturer who designed the engines say otherwise.
I figured it was all in my head. I could NOT see any change in MPG, drive ability etc.
