I'm looking to put some WS80s on my G35 coupe and was looking for some first hand experiences with them. I have never used a Blizzak but the WS80s seem to be getting quite positive reviews and they are reasonably priced. I will be mounting these on 17" rims in an unstaggered configuration of P215 55 17 so I can rotate them.
I will also likely need to replace the TPMS sensors. Is there any way to disable the TPMS light on a 2006 G35? The OEM TPMS sensors are ridiculously expensive at close to $100 each. That is 2/3 rds the value of the set of tires. Are the aftermarket sensors from Dorman okay? They are considerably less expensive.
