Take the spark plug out. Attach it to the ignition wire. Hold the plug to the engine block. Wear a glove. Get someone to pull the engine over. Is there a spark?
If yes, you have a gas issue. Dump the tank out. Put fresh gas in it. Put spark plug back in. Give it a pull.
If it doesn't fire up, buy a can of carb cleaner. Hose the inside of the carb out. Wait for 10 minutes. Give it a pull.
Its not rocket science. Its a lawn mower. I've fixed so many small engines from these few little steps. 99 times out of a 100 its [censored] gas.
