Off of brothers new to him 2011 GMC YUKON "hybrid" with 5.3 v-8. Had MaxLife 5w30 and this for 7,400 miles. 49,454 on vehicle. FRAM ULTRA and more MaxLife blend 5w30 in and on.
Looks like heck. Not enough louvers, the holes on top appear to be punched instead of drilled (don't like the rough edge because they hurt oil flow), and the pleats aren't perfectly spaced. Other than that it looks great.
Originally Posted By: bvance554
... the holes on top appear to be punched instead of drilled (don't like the rough edge because they hurt oil flow) ...
Doesn't make any difference when a PD oil pump is pushing the volume through the system.
Thanks Chief. I thought the sarcasm was obvious.
Hard to tell around this place sometimes ... might want to use some of these next time --->
Not bad, this is the same filter used by VIOC on my company 3.7 Transit, I did see they switched to Fram/Champ on the last one. Might be able to push it out to 7500 miles now.
