Originally Posted By: Chevy538487
Originally Posted By: FranklinJL
200 on a lost cost GM 5.3 is pretty good. That noise could be anything on that mill, they are not known as a well built engine in the first place, most I seen give up the ghost right at 180-240k
Well I plan to go as far as I can with her, [censored] good truck!
Only on this site would a 5.3L have a bad reputation, They try too compare their pampered European & Japanese mills to something that gets WORKED. I'm building a 4L60E out of a 2000 GMC 1500 with over 400,000 on the original 5.3L & it has a HUGE street sweeper on it, The truck probably weighs 12,000 pounds with the Sweeper...My 9.000 pound swing arm lift will not lift it! I had to sub-out the R&R as it won't clear my 13,000 pound drive on lift.
Broken Valve Springs take A LOT of these engines out, Starts out as a tapping noise, You need to have it checked for a broke spring &/or a collapsed lifter. A worn oil pump or a shrunk pick-up tube O-ring are also possibilities.
