THafeez, you're welcome.
Dyusik, its quite possible for it to leak if the spring isn't holding.
Rolla07, the filter isn't bad if its not mounted upside down. Due to the nature of my application on the forklifts, its mounted upside down and I much prefer filters with a silicone ADBV. If you look at the Wix I cut open the center tube is a bit different as well.
blupupher, Yes, this is the filter below the silver. What filter does it use? PH2/1372 size? If it is, I could buy one and cut it open for you, since I'm pretty curious myself.
