Originally Posted By: otis24
As a former GM salesman, let me say that I generally trust the OLM. Particularly when paired with a good synthetic or synthetic blend motor oil. My 2009 Chrsler T&C seems to go off at around 3k miles. It does not give a percentage, it just says "Change Oil". Is the just Chrysler covering their butt? I cant bing myself to dump good synthetic oil before 7k or 8k miles. Or a good conventional oil before 5k.
I can't say definitively, but I think Chrysler started out with very conservative OLM algorithms and has only recently gotten as sophisticated as GM. GM kinda led the way with OLMs going all the way back to the early 2000s.
My 2008 Ram OLM pretty much goes off every 3k, with only slight variations (it'll go slightly longer with all-highway driving and never using E85, but pretty much one tank of E85 will set it off at 3k miles). There's no percent remaining or any other indication until it says "oil change required."
My 2012 Challenger goes off at between 5000 and 7000 miles, so its less aggressive and also varies more. But like the Ram, there's no percentage, just a warning when it wants you to change the oil.
My wifes 2014 WK2 actually shows a percentage remaining like GM has done for quite a while now. We haven't had it long enough to see how variable it is.
