Originally Posted By: Shannow
Originally Posted By: ZeeOSix
Guess you just can't admit the information I showed is correct and your thinking is flawed. The link I gave above is a solid source of information.
Tribology International Vol. 30, No. 11, pp. 825–834, 1997
http://web.iitd.ac.in/~hirani/rapid_perfromancce.pdf
We are right back to the point where you don't think engine components are "force fed" oil flow by the PD pump. You do realize (I hope) that flow is forced any time there is a pressure difference across a flow path. That's about the simplest aspect of understanding fluids there is.
LOL, and THAT post before the edit too.
And that final statement, you have described before as your "belief" in what I'm believing.
There's simple fluids, and there's simplistic thinking regarding it, simplistic thinking that states that an electric pump feeding oil through a stationary shaft is identical to a running engine with all of it's dynamics.
Your position all along in these discussions is that the journal bearing is not actually
force lubricated by the oil pump. You've said it many times. If that's not your "theory" then you really need to try and explain exactly where you're at in these discussions. You instead keep deflecting and back peddling and never really stay focused on one discussion at a time. Just like these statements made by you (quote below) ... they don't align with what I'm saying and what information I've shown. And when I try to ask you a direct question on how you see something happening, you never respond and go off in the weeds with something else.
The part in red in your quote below clearly shows that you don't believe bearings supplied with high oil pressure by a PD pump are being "force fed" oil. You still believe that all journal bearings simply "suck" in the amount of oil they need (regardless of their supply pressure) due to their rotational dynamics and the tiny little vacuum they create due to their eccentricity while rotating. That "sucking in oil" part is true,
BUT ONLY for atmospheric fed bearings, NOT for pressure fed bearings - that is the important part you keep missing.
In pressure fed bearings with any significant positive supply pressure there is never any area inside the journal bearing that is below atmospheric pressure (ie, at any level of vacuum). There might be an area inside them that is slightly below the supply pressure, but never below ATM pressure.
Ahhh...there's your misunderstanding...they are not "resistive" at all...
they replace oil that leaks out of them in service with oil from the galleries, if they need less than the pump delivers, then oil pressure goes up.
You do not pump oil through a bearing at all...
A big journal bearing can actually SUCK oil into itself up quite a few inches of head,
so clearly, they are not being pumped into.
Here's a little visualization exercise for you to ponder. Lets say that Honda 2.4L V8 is running at a constant 10,000 RPM and everything in the oiling system is stabilized. Meaning all the journal bearings are floating where they want to be, and the oil flow in the entire oiling system is all going to where it wants to go.
Now magically stop the engine from running and keep all the mechanical components in the same exact physical positions they were in while running, BUT keep the PD oil pump still rotating at the same exact speed and oil volume output is was at when the engine was running at 10,000 RPM.
What do you think is going to happen to all that oil flow (~50 L/min = 13 GPM per the Honda paper, Figure 15) that is still coming out of the oil pump like the engine was still running at 10,000 RPM?
Since the oiling system is pressure fed by the PD pump, the same flow through everything is going to continue, and that includes all the journal bearings even though they are not turning because they are pressure fed. Do you agree with that? Or do you think the oil flow will magically stop and all the volume from the pump will pressure relief and shunt to the sump? Tell me what you visualize happening.
