List an oil Additive you'd use / No Comments
Quality motor oil...
But in a dirty, sludged engine on a beater: Rislone Engine Treatment...
Possibly a Liqui-moly product, but not likely.
I may use STP as a thickener if I change oil in an older car and it starts burning...
Bit of British culture for you.
While waiting for a train in a WH Smith's newsagent I found a "humour" book in a bargain bin. Titled something like "The Arthur Daley Book of Scams"
Arthur Daley was a British TV dodgy businessman character, with connections to the motor trade.
Flicked through it. The scams I looked at were plausible and some of them I'd seen in action in real life. Wish I'd bought the book.
In Arthurs bio, he was credited with inventing the nylon-shirt-in-the-gearbox trick. If I have another car with a failing gearbox (I once had a Marina gearbox which was mostly filings but continued to shift smoothly) I'll probably try it.
What about substituting a quart of regular oil with racing oil? For instance, if one were to use 4 or 5 qts of M1 0W30 with one quart of M1 0W30 racing oil, could this properly boost additives? Its about double the cost of a regular oil, so cheaper than many additives.
M1 0W30 VOA:
I'm surprised not many use LC20 given its popularity on this forum a number of years back. I've just ordered myself some for a piston soak, but other than that I don't add anything.
Graphited motor oil, cleaned my engine.
Look the dirt that came from between 2 pleats of paper, in a ocod.
That's smelly oxidated oil, plus sludge...
Strewth, I only just noticed the high Zinc, so if your engine does not have a CAT or DPF, this Mob 0w30 could indeed be used to boost the Moly and Zinc in some El-Cheapo dinosaur oil.
LM Motor Oil Saver
MMO (final few hundred miles before oil change for cleaning)
Risalone
I used some solid waxy like molybdenum once. It came from the leftovers in a barrel of MolyKote. There was always some that settled out at the bottom of the barrel.
