Originally Posted By: bullwinkle
Those numbers look AMAZING if you're not using a bypass filter system, I think you are adding just enough makeup oil to keep the TBN up, Si & soot actually DROPPING! Might be something to Schaeffer's full syn 9000 after all-or maybe it's just a Duramax.
I looked hard at bypass systems but I don't think I can justify their price as it will just cost me more money instead of saving.
I am looking at getting a amsoil full flow filter as they are supposed to last 25k miles and I have been changing mine around 15k which I need to change the filter.
I was worried that I had been adding topoff oil too close to the sample so I waited till after the sample to add any and the last I had added was at 166k.
