Originally Posted By: slacktide_bitog
Originally Posted By: Phishin
Just dropped the car off at the Honda Dealer:
They are going to flush the cooling system with BG's cleaner, rinse, and then install Genuine Honda Long Life Blue Coolant
They are going to do a complete ATF transfusion using BG's machine. They will use BG's ATF as a replacement fluid.
I also had them replace the factory in-line transmission filter. I'll be doing posting pics later of this original filter with 96k miles on it.
Honda specifically says NOT to machine flush any of their automatic transmissions
It's not a "machine" flush. It's like a transfusion. There is no "flushing", and does NOT use "pressure".
It's a simple machine that collects the old ATF and adds fresh ATF at the same time. It simply uses fresh fluid to push out all the old. It's completely safe.
