Around 130k changed original factory fill oil in the rear differential on a 2005 ford 9.75 rear. Ring/pinion and spider gears were perfect looking. Filled with 75w140 RP gear oil and motorcraft limited slip additive. 15k miles later passenger outer bearing/seal is leaking and causing the pass ebrakes shoes to smoke on highway. Opened up the differential now everything is covered in gray sludge, oil still light brown and clean, and ring and pinion has wear marks and spider gears have knicks all over them. Axles shaft wear surfaces still all looked good. Few metal specks on bottom of sump when I wiped it out. Now 3-5k miles on motorcraft synthetic 75w140 and motorcraft limited slip additive the rear axle is humming at 40+ mph. Did the royal purple gear oil have a bad reaction with the XL3 motorcraft LS additive?
I saved the old RP gear oil, guess I should send off a sample to have tested. Ive never had any problems with any oils; but i suspect this RP caused it. Gear oil was from AAP and got a good deal on it with coupon codes and LS additive was from ebay or amazon (maybe counterfeit copy?) trying to think of any possibilities. Any ideas?
