Originally Posted By: robshelton
All the new 2 stroke power equipment is set to idle very and I mean dangerously lean. I work on a lot of small engines as a hobby and usually one of the first things I do is pull the carb and "Defeat" the limiter screws. Many of the caps can be pulled off the mixture screws and reinstalled after you get it adjusted. But on some, I take some small diagonal cutters and snip off the nub that keeps the screw from turning.
Other things you should check are:
Spark - should be a nice blue color
Fuel tank vent
Fuel filter - on the gas line in the tank
Fuel screen in the carb
Fuel needle adjustment in the carb
A quick search found this page:
http://www.arboristsite.com/community/threads/husky-435-starting-problems.102175/
The last post is a guy that richened his idle mix screw 1/4 turn and it fixed his hot start problem. The tools are available on flea bay, BTW. Good luck!
EDIT After I looked at the IPL the saw probably has a "Stratified charge" engine. They appear to have two throttles but one is just for air. If so the intake "Pipe" is plastic and usually will not re-seal if you remove the carb. I have a 455 Rancher on the bench right now waiting to see what the owner wants to do. Needs the intake-large air leak.
I have not removed the carb but the saw is a refurb so who knows.
I've ordered a new NGK sparkplug to replace the Husky HGT-1 currently in. Figured try the cheap/easy solutions first then see.
If it's not the plug I'll go down your list. Thanks.
